ubuntu 21.10 + QEMU + arch linux
Post Reply
antix666
Post by antix666 » 2021/02/28 Sun 10:58 am
우분투 21.10에 QEMU를 사용하여 아치 리눅스를 돌리고 있습니다.
Neofetch에 나오는 디스트로 아이콘 만자로는 명령어로 살짝 바꾼 겁니다.
스크린샷, 2021-02-28 10-54-37.png (2.02 MiB) Viewed 247 times
User avatar
황병희
Contact:
Re: ubuntu 21.10 + QEMU + arch linux
Post by 황병희 » 2021/02/28 Sun 12:20 pm
오! 깔끔하고 시원시원합니다!!
1테라바이트의 디스크용량이 쪼매 부러웠습니다^^;;;
제 장비 크롬북(Ubuntu 18.04 LTS) 은 디스크용량이 총 32기가랍니다~ 으함;;;
Code: Select all
(bionic)soyeomul@localhost:~$ df -hT
Filesystem                                              Type          Size  Used Avail Use% Mounted on
/dev/mmcblk0p1                                          ext4           25G   17G  6.7G  72% /
devtmpfs                                                devtmpfs      2.0G     0  2.0G   0% /dev
shmfs                                                   tmpfs         2.0G   32M  1.9G   2% /dev/shm
tmp                                                     tmpfs         2.0G  724K  2.0G   1% /tmp
tmpfs                                                   tmpfs         394M   36K  394M   1% /run
tmpfs                                                   tmpfs         5.0M     0  5.0M   0% /run/lock
run                                                     tmpfs         2.0G  524K  2.0G   1% /var/host/dbus
/dev/mapper/encstateful                                 ext4          7.3G  463M  6.8G   7% /var/host/timezone
/dev/root                                               ext2          2.0G  1.3G  639M  68% /lib/modules/4.19.155-10578-g5c9157f34b72
media                                                   tmpfs         2.0G     0  2.0G   0% /var/host/media
none                                                    tmpfs         2.0G     0  2.0G   0% /sys/fs/cgroup
none                                                    tmpfs         2.0G  4.0K  2.0G   1% /sys/fs/selinux
fuse.drivefs:drivefs://9E8C87AA2EAFF10A772D63B5946108F3 fuse.drivefs   17G  2.5G   15G  15% /var/host/media/fuse/drivefs-c124b356dddc25535d78f18e9723610b
[우분투 18.04 파여폭스 나비에서 적었어요~]
^고맙습니다 감사합니다_^))//
Post Reply
